GRIZ Sextant (Raspberry Pi Cyberdeck)
On-topic CrowPi related news and discussions not covered by the other forums
wizzy
Post by wizzy »
https://imgur.com/a/BkcIFII
GRIZ Sextant (Raspberry Pi Cyberdeck) - another effort at a Rpi laptop.
I would like further details of the back-of-the-board USB connection, so you do not need the out-n-in USB cable
https://www.youtube.com/channel/UCnmjLV ... aprpLuw2LQ
YouTube series - also he puts in a power booster. For people here, I think the best is to run it off the barrel jack.
CrowPi designers put the power components in the unit - so, use them - from 12V.
For me it would be more convenient from 18V - my power drill battery - or even 19V - the inevitable old laptop charger doing nothing.
2600Sam
Re: GRIZ Sextant (Raspberry Pi Cyberdeck)
Post by 2600Sam »
It looks a little clumsy and small and with the release of the Pi400 why bother!
StevTheme
Post by StevTheme »
I downloaded the 64bit image for the Raspberry PI 400, newest 2020.04 mentioning RPI 400. After booting, wifi does not show up, ifconfig does not list it. How do I enable wifi?
Thanks.
2600Sam
Re: -
Post by 2600Sam »
StevTheme wrote: Wed Feb 17, 2021 9:34 pm I downloaded the 64bit image for the Raspberry PI 400, newest 2020.04 mentioning RPI 400. After booting, wifi does not show up, ifconfig does not list it. How do I enable wifi?
Thanks.
try this
I don't remember if this is required any more.
In a terminal window type in
Code: Select all
sudo raspi-config
then 'Localisation Options' - then set your locale, timezone and WLAN country.
if that doesn't work try this
Code: Select all
sudo apt update
sudo apt install firmware-brcm80211
