I got an error similar to :
Traceback (most recent call last):
File "./matrix_demo.py", line 120, in <module>
demo(args.cascaded, args.block_orientation, args.rotate)
File "./matrix_demo.py", line 20, in demo
serial = spi(port=0, device=0, gpio=noop())
File "/usr/local/lib/python2.7/dist-packages/luma/core/interface/serial.py", line 281, in __init__
self._spi.cshigh = cs_high
SystemError: error return without exception set
The advice was to revert the spidev driver back to a previous version with the following command :
pip3 install spidev==3.4 --force-reinstall
