https://imgur.com/a/BkcIFII
GRIZ Sextant (Raspberry Pi Cyberdeck) - another effort at a Rpi laptop.
I would like further details of the back-of-the-board USB connection, so you do not need the out-n-in USB cable
https://www.youtube.com/channel/UCnmjLV ... aprpLuw2LQ
YouTube series - also he puts in a power booster. For people here, I think the best is to run it off the barrel jack.
CrowPi designers put the power components in the unit - so, use them - from 12V.
For me it would be more convenient from 18V - my power drill battery - or even 19V - the inevitable old laptop charger doing nothing.
Re: GRIZ Sextant (Raspberry Pi Cyberdeck)
It looks a little clumsy and small and with the release of the Pi400 why bother!
I downloaded the 64bit image for the Raspberry PI 400, newest 2020.04 mentioning RPI 400. After booting, wifi does not show up, ifconfig does not list it. How do I enable wifi?
Thanks.
Thanks.
Re: -
try this
I don't remember if this is required any more.
In a terminal window type in
sudo raspi-configif that doesn't work try this
sudo apt update
sudo apt install firmware-brcm80211
